DW2016
Aug 30, 2016Follower
Mapping Network Drive for Windows
Hi, I've got my ReadNAS 31200 set up and working and I'm now wanting to create two levels of high level folder (or share) - one that only I have access to and one that my team of 3 have access to. I'...
Aug 30, 2016Guru - Experienced User
Your home share is showing up because the PC is presenting your user credentials to the NAS.
If you want to see what the others on the team will see, you need to use their credentials.
JennC
Aug 30, 2016NETGEAR Employee Retired
Hello DW2016,
This FAQ might help you. Once you access the volume of the NAS, the computer remembers your login and keep using it until you disconnect from the volume. You need to disconnect from the NAS drives first to get other users connect and test or see if access rights you have set are working as expected.
Welcome to the community!
