Hamio's avatar
Hamio
Minidlna Error?
I have a ReadyNAS RND4000 running RAIDar 6.4.0 and Radiator 4.1.16.
I'm sharing my MP3s and jpgs using the minidlna (1.1.14) included with that system.  It appears that all my Roku devices and PCs can see and access mp3s and jpgs no problem.  However, when I attempt to access the all the jpg folders with my Pix-Star picture frame wirelessly, the frame hangs up and I have to back out of it's menu to start over.  If I access individual folders on the NAS from the Pix-Star there is no problem, pictures in the selected folder display properly.
I've checked the upnp-av.log on the NAS and I notice what appears to be an error:
2018/09/06 21:50:30] upnpsoap.c:757: error: UPnP SOAP response cut short, to not exceed the max response size [2097152]
[2018/09/06 21:50:30] upnpsoap.c:1308: warn: SQL error: callback requested query abort
BAD SQL: SELECT o.OBJECT_ID, o.PARENT_ID, o.REF_ID, o.DETAIL_ID, o.CLASS, d.SIZE, d.TITLE, d.DURATION, d.BITRATE, d.SAMP
Any ideas on what the problem might be?  Could it be memory related?
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi Hamio
    Welcome to the Community!
    Can you enable Readydlna debug and provide us what is happening? We may have to check further to properly assist you.
    Readydlna add-on
    Regards
    • bedlam1's avatar
      bedlam1
      Prodigy
      Is there an OS 6 addon for Toggle ReadyDLNA Debug? or a SSH method for doing it
    • Hamio's avatar
      Hamio
      I've downloaded and installed the addon, however, I don't see a toggle on the admin pages.  Is this a command line action?
    • Hamio's avatar
      Hamio
      Well, I should've looked a little closer...it's already activated.  I'll capture some of the upnp-av.log file and post.  Thx.
ProSupport for Business
