Jemini
Dec 02, 2011Aspirant
Mldonkey's dir problem on NV+ [updated]
Hi all, I'm about to ask for help about mldonkey on NV+.I can not find the Mldonkey download file from it's directory (media/Mldonekey). There is only one sub-directory here: .mldonkey, the other o...
Jemini
Dec 04, 2011Aspirant
Here some useful information from the "sysinfo" tab of Mldonkey
You notice that the share of "media" I found in my 1st post is (/media/Mldonkey) which is not (c/media/Mldonkey), that's why I can not see the directories of Transmission and Mldonkey while it is an ini file directory, anyway.
So, it it the common problem? How to recovery the real media share? Thanks
/c/media/Mldonkey/incoming shared (incoming_directories) 2.49T 1.07T 30% ext2/3
/c/media/Mldonkey/incoming/files shared (incoming_files) 2.49T 1.07T 30% ext2/3
/c/media/Mldonkey/shared shared (all_files) 2.49T 1.07T 30% ext2/3
/c/media/Mldonkey/temp temp/downloading 2.49T 1.07T 30% ext2/3
/media/Mldonkey/.mldonkey core/ini files 449.7M 1.50G 77% ext2/3
incoming/directories shared (incoming_directories) 449.7M 1.50G 77% ext2/3
incoming/files shared (incoming_files) 449.7M 1.50G 77% ext2/3
mlnet_tmp $MLDONKEY_TEMP 449.7M 1.50G 77% ext2/3
shared shared (all_files) 449.7M 1.50G 77% ext2/3
