Oliver_YE
Feb 06, 2024Aspirant
My iPhone/iPad can't access My ReadyNas(RND2000 V1) share drive
Hello, I have ReadyNAS for file storing and sharing in my home, but I can't access the share drive from iPhone/iPad file apps,but My Windows 11 laptop can access without any problem. it's not acc...
saudade
Feb 07, 2024Apprentice
Did it ever work? Did you just update IOS?
I have a Duo V1 and an iPhone 7 (yes I know it's old) with IOS15.8. I've never been able to connect to either the Duo, my WD EX4 or my USB Drive on my Netgear router (Readyshare) directly using Files. I use an app called ES File Explorer.
On my Win11 I had to turn on the SMB 1.0 in Windows Features (in control panel) in order to browse through the shares.
- Oliver_YEFeb 13, 2024Aspirant
No, still dones't work with my iPhone/iPad, and I have a HP Proliant Microserver Gen8 which is installed Windows Server 2012 R2 for file sharing, the HP Gen8 can work with iPhone/iPad very well.
- schumakuFeb 14, 2024Guru - Experienced User
Oliver_YE wrote:
... But iPhone/iPad File Apps can't work with ReadyNAS......
Are you on your legacy ReadyNAS supporting only SMB 1.0/CIFS protocol, and hanging on the Apple Apps not support neither SMB 1.0 nor CIFS client? Well, this can't be enabled on this modern mobile phone Apps at all. That's why somebody mentioned using a third-party App, where the devs hav implemented some user space SMB 1.0/CIFS client, not sure by how far this is possible on iOS.
- StephenBFeb 14, 2024Guru - Experienced User
ES File Explorer also supports FTP, which will work with the legacy NAS.
