moonshadow
Mar 04, 2015Aspirant
MySQLON won't install, can't turn add-ons on in Frontview
Hi, I believe I had some corruption in the MySQL database that caused my Newznab installation to crash. In Frontview, the MySQLON light was grey and I was unable to restart the add-on. So, I th...
moonshadow
Mar 05, 2015Aspirant
Thank you for your response mdgm, and once again you are spot on. The OS partition is full.
I had considered, and immediately dismissed, the possibility that the OS partition was full, because I had moved the MySQL databases to /c/databases (or so I thought) before installing Newznab, but I obviously did something wrong. I'm still too much of a Linux noob to figure out how to check the free space.
Anyway, now I have a research project to figure out how to clear out all the clutter in the OS partition, though I'm fairly apprehensive about tinkering around in there. I would welcome any suggestions.
Cheers,
Moonshadow
Cheers,
Moonshadow
