dudeeg
Jun 21, 2011Aspirant
Nas Monitor uninstall problem
Hi! Yesterday I installed PHP5 5.2.17 (by WhoCares?) on my Ultra2, and also the Nas Monitor package (by super-poussin). I played with Nas Monitor a little, and after that I decided to remove the pa...
WhoCares_
Sep 16, 2011Mentor
Well, the basic problem is that the file NASMONITOR.js has two tiny little errors in it which effectively prevent the remove function from being called.
If you have SSH access to your ReadyNAS, you can remove the add-on by calling
on the command line.
-Stefan
/bin/bash /etc/frontview/addons/NASMONITOR.remove
-Stefan
