andrea_santini
Sep 02, 2022Aspirant
NAS RN31443D freezes after a few minutes of use
Hello everyone, I have this problem. The NAS freezes after approximately 30 minutes of use. I'm afraid it's one of the 4 discs. I would like to do a single test for each disk, but I don't understand how to do it. I only find the option to test the whole disk pool.
I still ran this type of test, but after a few minutes the NAS freezes. I also tried running a SCRUB, but it always crashes at 0.7%.
How can I find out which hdd (s) have problems?
I checked the logs, but they don't report anything abnormal.
Grazie
Unfortunately I don't understand what the problem is. I bought another NAS in consideration of the fact that this NAS was already 8 years old. Thanks anyway for the invaluable help.
andrea_santini wrote:I checked the logs, but they don't report anything abnormal.
All stats in disk_info.log look clean?
Are you comfortable using ssh? It is easy to do read tests on individual drives with smartctl.
It's possible that the freeze isn't linked to a drive issue. Are you seeing any warnings related to a full root partition?
- andrea_santiniAspirant
Thank you.
Even using SSH, it crashes after a while.
Monday I check what you told me.- StephenBGuru - Experienced User
andrea_santini wrote:Even using SSH, it crashes after a while.
smartctl -x /dev/sda should give you details of what errors (if any) the disks have in their logs (using the appropriate names for the other drives of course).
- Jan 17, 2024Retired_Member
