davidpw
Apr 03, 2012Aspirant
NASMON and LoadAvg
I seem to be having the same problem tht some others have reported in the forum. The other modules work fine, however when I try to launch LoadAvg I get an error from the browser window: Firefox ha...
Sandshark
Oct 08, 2013Sensei
dsm1212 wrote: I looked through all 4 modules and what I see wrong is: 1) loadavg timezone is incorrect so 0 on the graph his not midnight. 2) no smart info on the phpsysinfo page. 3) processes listed on the phpsysinfo page are odd. explorer.exe??? They must be hardcoded somewhere.
Otherwise looks pretty accurate.
BTW I'm using Whocares php addon (not the very latest, the prior version). Maybe the issues are really with Super's PHP addon?
steve
You have to set the correct timezone in PHP.INI. It's at the bottom. When you edit from within FrontView, the SAVE button is almost unseen to the right of the Cancel button. You can find your correct PHP timezone here: http://us2.php.net/manual/en/timezones.php.
