davidpw
Apr 03, 2012Aspirant
NASMON and LoadAvg
I seem to be having the same problem tht some others have reported in the forum. The other modules work fine, however when I try to launch LoadAvg I get an error from the browser window:
Firefox has detected that the server is redirecting the request for this address in a way that will never complete.
IE does not work either.
Is there a solution to this?
David
David
- dsm1212Apprentice
Sandshark wrote:
You have to set the correct timezone in PHP.INI. It's at the bottom. When you edit from within FrontView, the SAVE button is almost unseen to the right of the Cancel button. You can find your correct PHP timezone here: http://us2.php.net/manual/en/timezones.php.
Thanks, I found it and made the change, but nasmon still looks wrong. I set it to America/New_York. Entering php -i shows it with this new value so it seems to have taken. I rebooted. The title at top of nasmon screen shows:
Today - Wednesday, Oct. 9 - last update at 2242 (10:42 pm) CEST
But it's only 4:48PM. Maybe this is due to old data and it will be better tomorrow?
