hells_mels
Mar 20, 2020Aspirant
NETGEAR ReadyNAS DUO is Dead
Hi there, My old RadyNAS Duo appears to have given up the ghost and will not boot anymore. I'm prepared to replace it with a new one, but does anyone know if I can simply take the drives out ...
- Mar 23, 2020
hells_mels wrote:
I'm going to factor in the cost for a small UPS
That is a good idea - something I generally recommend and do myself. Not only does it offer some protection against power surges, it also allows the NAS to shut down cleanly when the battery in the UPS drains. That avoids losing writes in the cache - which can result in corrupting the file system.
Sandshark
Mar 20, 2020Sensei - Experienced User
You could move the drives to another used Duo, but I don't recommend it. You cannot move the drive directly to a current ReadyNAS and use them as-is, but there is a procedure, with Netgear paid assistance, to access the files on the drive using a current NAS and back them up, if you don't already have a backup from which to restore the files on your new NAS.
Mar 20, 2020Guru - Experienced User
You can also connect disk 1 of the NAS to a Windows PC (either with SATA or a USB adapter/dock) and access the data with R-linux for Windows (free). https://www.r-studio.com/free-linux-recovery/
- hells_melsMar 21, 2020Aspirant
Thanks very much Sandshark and StephenB for your replies and tips.
I'll take a look at R-Linux for Windows and hopefully it won't exceed my technical abitlities and might help.
In the meantime I've tried taking a look at getting "NETGEAR paid assistance" in the event I need to try and get my files back. Would anyone know how to arrange this?
It's not clear whether I should go for the Gearheads or NETGEAR Premium? Do I pay for a one-off incident or 6 months or 1 year?
As always your suggestions are much appreciated.
Kind regards,
Mel
- StephenBMar 22, 2020Guru - Experienced User
Certainly not gearheads.
If R-linux doesn't work, you'd likely need data recovery: https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
- hells_melsMar 22, 2020Aspirant
Thanks StephenB for the tip to try R-Linux.
It worked really well, was suprisingly straightforward in use and I managed to get all my files back! Which I've copied to a portable hard drive. So thanks again for that tip.
Hope you won't mind if I ask your advice on a replacement for the Duo?
I initially, because of the potential unreliability of mechanical drives, went for the Duo for the peace of mind of mirroring my data to two drives. Even though the Duo has given pretty good service, I'm aware I haven't taken into account unreliability of the disk presenting/serving hardware.
I haven't got the budget to go to a proper business class storage array but I was wondering if there was a platform where I could have just removed the drives from my existing device and put them in a new one without data loss?
Kind regards,
Mel
