Xaver's avatar
Xaver
Tutor
Feb 13, 2010
Network bridge error
Hi,
i've tried to bridge my eth1 with the tap0 device for using it with openvpn in bridging modus.
I've executed the brctl addbr command as follows: 'brctl addbr br0' which leads to the following error:
add bridge failed: Invalid argument
I've tried to update bridge-utils but I can't find a newer version then 1.2.1.
Attached you can find a strace output fpr my brctl command. It would be nice if someone could help me out with this problem...
readynas-pro:~# strace brctl addbr br0
execve("/usr/sbin/brctl", ["brctl", "addbr", "br0"], [/* 15 vars */]) = 0
brk(0) = 0x804e000
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xf7ee3000
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=18669, ...}) = 0
mmap2(NULL, 18669, PROT_READ, MAP_PRIVATE, 3, 0) = 0xf7ede000
close(3) = 0
open("/lib/libsysfs.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\220%\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=44792, ...}) = 0
mmap2(NULL, 47852, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xf7ed2000
mmap2(0xf7edd000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa) = 0xf7edd000
close(3) = 0
open("/lib/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260e\1"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=1294572, ...}) = 0
mmap2(NULL, 1300080, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xf7d94000
mmap2(0xf7ecc000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x138) = 0xf7ecc000
mmap2(0xf7ecf000, 9840, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xf7ecf000
close(3) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xf7d93000
set_thread_area({entry_number:-1 -> 12, base_addr:0xf7d93ad0, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}) = 0
mprotect(0xf7ecc000, 4096, PROT_READ) = 0
munmap(0xf7ede000, 18669) = 0
socket(PF_INET, SOCK_STREAM, IPPROTO_IP) = 3
brk(0) = 0x804e000
brk(0x806f000) = 0x806f000
open("/proc/mounts", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0444, st_size=0, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xf7ee2000
read(4, "rootfs / rootfs rw 0 0\n/dev/md0 "..., 1024) = 456
close(4) = 0
munmap(0xf7ee2000, 4096) = 0
lstat64("/sys/class/net", {st_mode=S_IFDIR|0755, st_size=0, ...}) = 0
ioctl(3, 0x89a0, 0xff895eab) = -1 ENOPKG (Package not installed)
ioctl(3, SIOCSIFBR, 0xff8953e0) = -1 EINVAL (Invalid argument)
write(2, "add bridge failed: Invalid argum"..., 36add bridge failed: Invalid argument
) = 36
exit_group(1) = ?
Process 3005 detached
  • Thanks Stefan, I got one step closer.
    Now everytime I create a bridge, 30 sec after, I loose connection to the NAS, until I reboot. do you have any suggestions?
    thanks again for your help
  • Without the output from "dmesg" or excerpts from /var/log/syslog and /var/log/messages there's not much I can suggest. Maybe there's a background task on the ReadyNAS checking for network connections that is getting confused by the bridge setup but I honestly don't know.
    -Stefan
  • Hi Whocares.
    Did you do any other work on the bridge-utils?
    I would appreciate the module for the sparc platform.
ProSupport for Business
