super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- silvercueAspirant
santa wrote: Hi,
I got a problem with Transmission stops running after a few minutes. Any ideas?
I am running Transmission v2.33 (sparc) on RAIDiator 4.1.7
I have also tried to run Transmission 2.32 beta 2, but same problem there.
Exactly the same problem I have (post a few back)...though now I can;t even connect to the interface.
This is just not working for me :( - santa1AspirantDu you know if the publisher of Transmission has commented on the mather?
- santa1AspirantLooks like Transmission is using all the memory, and therefor shuts down. Any ide how to fix this without adding more ram? I am curently running with 256 mb ram.
- n0guestAspirantit's huge memory leak. I've Tested on 2.31, 2.33 with my Duo with 256Mb RAM, RAIDar 4.1.7.
confirmation that this is a memory leak - information in the output of utilities top and logs in /var/log/syslogAug 21 22:25:32 duo kernel: Out of memory: Killed process 10319 (transmission-da).
Aug 21 22:25:32 duo kernel: Out of memory: Killed process 10320 (transmission-da).
Aug 21 22:25:32 duo kernel: Out of memory: Killed process 10321 (transmission-da).
Aug 21 22:25:32 duo kernel: Out of memory: Killed process 10322 (transmission-da).
if transmission-daemon only started (or verifying files) - all is ok, memory consumption 5-8Mb.
when add torrent, but not start it (not downloading) - same situation with memory usage.
start torrent downloading and memory leaking on 3-5Mb with 10 seconds.
i'm tried to disable utp, dht and change some other settings - no result.
think memory leak is related with the downloading torrents data, but how fix it?
super-poussin, can you help to locate and fix this leak?
I am willing to offer a reward for your help in solving this problem (eg, paypal donate).
moreover, that according to previous reports, this problem affects many users.
ps: if you do not want or for whatever reason can not help to solve this problem,
please, I would like to hear your opinion on the possible solutions to this problem. - JarnoGGuideI had the permission denied error too at first. It turned out that the folders Transmission was using to put the incomplete/completed files did not have write permissions for the Transmission user (nogroup / nobody). After getting the permissions and folders right, everything works ok with me, though it usually hogs up a lot of memory when it's downloading. I think the standard setting is that it is using a buffer of 2GB i think, which is a bit more than the memory in a Duo...
- crabby1AspirantI'm getting the memory leaks too... Transmission crashes in about 30 minutes. Anyone with upgraded memory get this?
I heard going back to 2.22 helps... Anyone confirm this?
crabby - n0guestAspirantIn my case (installed original 256Mb memory, not upgraded or replaced) helped only downgrading to version 2.11.
My ReadyNAS Duo running second day without Out-Of-Memory killing.
Transmission up and running normally - used in total 20-30Mb, seems memory leak stopped.
I'm still waiting for a response from the super-poussin, perhaps he will tell what the problem with newer versions of Transmission (> 2.11).
May be his Transmission builds require some newer versions of libevent/libcurl not available on RAIDar 4.1.7 and early versions.
In my past experience is a version mismatch of libraries can lead to crashes, memory leaks and other failures.
But we need confirmation from the super-poussin - what library versions he was used to compile Transmission. - Blues11LuminaryI would still like to install Transmission. As I posted one or two pages ago, I upload and confirm that I want to install. Then as soon as it starts I get the message: Installation of this add-on conflicts with an existing service. Aborting installation. When I go to the "Add-ons" page there's nothing listed..
Any help would be appreciated. Thank you. - silvercueAspirantreading your posts I think I would like to uninstall latest Transmission as it simply doesn't work for me and try the older version 2.11.
I have RAIDar 4.1.7 as I use 3TB drives.
How do I do this?
I am using a Readynas Ultra 2.
Thanks - silvercueAspirantI have uninstalled and then installed 2.11 and it works fine.
