super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- Andreas75kAspirant
phantomwhale wrote: Apologies, where can I get the latest version ? The main thread doesn't seem to have links to 2.33.02 and 2.34.04 ?
I see links to those on the first post here: viewtopic.php?t=24271 - mateuszwdowiakAspirantHello,
Recently I've been using Transmission 2.31, but the out of memory exception occured, so i got back to Transmision 2.11...
Downloading torrents seems to be ok, but i have a problem with uploading- there are always only 0 or 1 peer available, but most of the time there is no peers available.
The port is open on my router, so I don't know what else can i do...
Maybe i can change anything in the settings or something?
Do you have any ideas? - Andreas75kAspirant
mateuszwdowiak wrote: Hello,
You can try the new beta from here:
viewtopic.php?t=24271#p133300 - mateuszwdowiakAspirantok, i will try it later, cause now i'm downloading a large file..
But i thing, that it won't help, because i had this problem with the other versions too, Transmission 2.30 and 2.31
do you have any other idea? - Linus2822AspirantHi
Since 2.24.04 installed, Transmission remote .Net shown only unknown Status and Downloading Stauts.
Paused or seeding is not shown :/
Does anyone have the same problem?
In the webinterface is all fine.
Greetings
Linus - phantomwhaleAspirant
Linus282 wrote: Hi
Greetings
Linus
Yes, I pulled down the latest version (which is working very nicely, thanks) and noticed exactly the same.
That said, the web interface has been quite responsive, and much improved since I last used it, so I'm happy going back to that.
Not sure where the fix might be to get the remote GUI working again ? - BennTechAspirantGood news, bad news with 4.1.8:
Bad news that the 4.1.8 upgrade breaks Transmission add-on 2.31 (at least service refused to start for me on 2 ReadyNAS NV). Didn't troubleshoot much because good news is that 2.34b04.
More minor bad news for a select few is that v2.34b04 breaks status in Transmission Remote DotNet. Status is either Downloading or Unknown, but no Paused, Seeding, etc.. Annoying, but otherwise functional. - Linus2822AspirantSo what to do?
Just wait for a new version of "Transmission Remote .net" or is the problem located in the addon? - BennTechAspirant
Linus282 wrote: Just wait for a new version of "Transmission Remote .net" or is the problem located in the addon?
Just to reiterate, Transmission Remote .NET is still functional. You can add, start, pause, and delete torrents, traffic graphs and percentages work, and with working percentages, Transmission Remote knows whether a torrent is complete or not. The only thing that doesn't work is the status. It only recognizes Downloading status, but not Seeding or Paused. Unfortunately, this means category filters, like Paused or Seeding, don't work. Neither do the status column and status icons, which leaves you with no way to tell in Transmission Remote if a completed torrent is seeding or paused.
Obviously, 2.34b04 broke this, but I don't know if this is a bug in 2.34b04 or if it is a change in the Transmission protocol that Transmission Remote needs to adopt. Maybe super-poussin can weigh in here?
All that said, I recommend Transmission users DO NOT upgrade to 4.1.8. However, if you did or must upgrade, then you must to upgrade to Transmission 2.34b04, too. Personally, I plan on downgrading back to 4.1.7 and 2.31. - dgerson76AspirantJust upgraded to 4.1.8, I probably should have read this thread first :/
All I can see now after upgrading transmission to the latest beta is this-
I assume all I can do is wait for the upgraded version of Transmission?
Thanks
