super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- jptdemanAspirant
hobbes487 wrote: I tried reverting back to 4.2.17 and Transmission still won't start. The only other thing that has changed is that I changed some users and permissions on some of my shares, Could that have caused Transmission to stop working?
In case You het Permission Denied error, delete folder Downloads and let it recreate via webinterface. - JarnoGGuideIf you changed the permissions of the addons-config share, then it might be possible that transmission can not read its settings-file and thus won't start. In that case, you should make sure that the user "nobody" (without "") has read/write permissions on that share
- ranthony1AspirantHi guys,
I configured transmission 2.33.02 last night. I have a question regarding encryption. What is the difference between;
"encryption": 2
"encryption": 1
Does one provide better encryption over the other? Is there any performance impact? - btaroliProdigy
ranthony wrote: I configured transmission 2.33.02 last night. I have a question regarding encryption. What is the difference between;
"encryption": 2
"encryption": 1
There are links to it from the add-ons forums (as Transmission Parameters), but you probably want to take a look at http://www.readynas.com/contributed/sup ... meters.htm - ranthony1Aspirant
btaroli wrote: ranthony wrote: I configured transmission 2.33.02 last night. I have a question regarding encryption. What is the difference between;
"encryption": 2
"encryption": 1
Yes, I've seen this. It doesn't answer my questions completely though but thank you for responding. - Mr_BGuide
There is only one. There can be only one. Everyone has to understand one and other.ranthony wrote: Does one provide better encryption over the other?
Yes. Encryption relies on CPU calculations, so encrypted transfers cost CPU time. This should be weighted against the fact that some use encryption, some don't. If you go with 0 or 2 you can only talk to people who have the same setting, or 1. So for maximum availability of peers, 1 should be your choice. Then you can talk to everyone. (0 = Off, 1 = Preferred, 2 = Forced)ranthony wrote: Is there any performance impact?
I'd like a 4'th option here actually. Encryption enabled, but unencrypted Preferred. But 1 works well enough.
B! - ranthony1Aspirant
I was referring to the options, 1 or 2.
B!
Thanks for this, it helps. - Mr_BGuide
I was only clarifying, your question sort of indicated that there were alternative encryption methods in use. I'm honestly not up to date on exactly how the encryption works, but to keep snooping eyes out it would seam likely that you follow a set of rules and use a random salt, and simply trade the salt during initiation of the transfer.ranthony wrote: I was referring to the options, 1 or 2.
Anyway, i guess "better" could mean reliably encrypted, in which case 2 is the only way to go. With any other option your going to have stuff that isn't encrypted.ranthony wrote: Does one provide better encryption over the other?
No worries, i'm happy the little i know can be useful from time to time. If nothing else it makes me look good, as a good counterweight for the times when i look like a complete fool.ranthony wrote: Thanks for this, it helps.
B! - super_poussinVirtuoso2.5.0 is on the way
- JarnoGGuideDo you have any idea on the ETA? I'd love to be able to add magnet links again without crashing...
The Transmission website mentions 2012-02-xx, but that usually means "somewhere in the future"...
