super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- jz11Aspirant
super-poussin wrote: MrAsker wrote: dr3as wrote: Is there any eta on a sparc version? :-)
This I also would like to know ... :)
My duo dies last week, I'm looking for a replacement hoping the disks are good
sorry for this guy
Also interested in it. Reverted to old version becouse of problems with latest version that it freezes after a while(transmission). So hoping 2.50 fixes it. Just posting to let u know there is more interest!
Still great work ofcourse! - WhoCares_Mentor
mcpeterc wrote: Installation of this add-on conflicts with an existing service. Aborting installation.
If you have SSH access to your ReadyNAS, go to the /etc/default directory and edit the 'services' file there. Delete every line that starts with "TRANSMISSION", save the file and then retry installation. Should work.
-Stefan - Mr_BGuidePerhaps a stupid question, but how do you go about to update the current transmission thingy installed on the NAS? I got 1.5TB in 8 torrents that i'd like not to readd. The hash calculations takes for ever. Did that with the beta, and it wasn't that fun.
B! - mdgm-ntgrNETGEAR Employee RetiredIs this the NV+ v1 (i.e. Sparc) you have? If so, it hasn't got a 2.50 update yet. The developer's NAS died. See http://www.readynas.com/forum/viewtopic.php?p=344075#p344075
The Transmission thread for Sparc is here: http://www.readynas.com/forum/viewtopic.php?f=47&t=24271
Installation is via System > Update > Local. When you update an add-on it runs the add-on remove script in a way that preserves add-on configuration. - Mr_BGuide
Yeah, i saw, poor fella. And yes, it's for a future update on a NV+ v1mdgm wrote: Is this the NV+ v1 (i.e. Sparc) you have? If so, it hasn't got a 2.50 update yet. The developer's NAS died.
So simply install as if it was the first, and it should behave properly. 'aight. Thanks.mdgm wrote: Installation is via System > Update > Local. When you update an add-on it runs the add-on remove script in a way that preserves add-on configuration.
B! - MaxPower1AspirantHey All:
General question (and forgive me if this has already been answered): Does the current version of Transmission for the Duo allow for the use of Proxies or not? I've seen conflicting information from '09, '10 time frames that say it does, then others (like the Transmission wiki) that says it does not.
As Live would say - "the confusion sets in..."
Thanks for the help!
Max - DavidtHulinAspirant
mcpeterc wrote: When I am adding new torrents they download 3-4% and then stops. Inside transmission remote the torrents goes red (broken)??
I just fatory reset my nas (NVX) and updated transmission to newest version. Does anyone have a clue here?
Regards
EDIT: Oh I can see theres an error: Error: Permission denied (/c/media/BitTorrent/torrantname) Where do I set permissions correct?
EDIT2: I have now enabled SSH access and logged in as root. But what do I do now?
I have EXACTLY the same problem. And I have tried to find a solution with no luck. Tips?
Thanks,
David - DavidtHulinAspirant
JarnoG wrote: Follow the advice given here.
Make sure you do that for all shares that contain a folder used by Transmission (downloaded folder, incomplete folder, etc)
It worked perfectly! Last time I missed the checkbox.
Thanks!
D - frelar8AspirantSo I am new to Transmission and has installed it on my ReadyNAS Duo. Unfortunatley I cannot get it to work properly:
When I add magnet link it starts download and all seem fine for a while. After a random time interval the pop-up "Connection FailedCould not connect to the server. You may need to reload the page to reconnect." displays and Transmission is no longer responding to anything. Only way to get it running again is to disable and re-enable Transmission in ReadyNAS Frontview. Same behaviour on both 2.42 and 2.31.
Any idea on what is wrong and how I can fix it?
