super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- Mr_BGuide
Seeing as it's been a while... Had any luck? Or should we expect that 2.42 was the last release from you in the long line, for sparc's?super-poussin wrote: MrAsker wrote: dr3as wrote: Is there any eta on a sparc version? :-)
This I also would like to know ... :)
My duo dies last week, I'm looking for a replacement hoping the disks are good
sorry for this guy
That would suck, hope you get it sorted.
Cheers.
B! - super_poussinVirtuosoI hope by the end of the month as soon as I get a new unit
- gibxxiGuideSorry for cross-posting, but any chance of a Subsonic update for x86 super?
:) - AMRivlinApprentice
gibxxi wrote: Sorry for cross-posting, but any chance of a Subsonic update for x86 super?
I second this, would like x86 updates for Subsonic. Thanks - Mr_BGuideBlocklist exclusion... Is it possible? Seams for one reason or another one of my trackers doesn't respond well to being in the blocklists...And dissabling the blocklist feature from Transmission Remote Dotnet doesn't do jack shi....
If it cant be excluded i'll stick those torrents on the PC instead, but the point of having them on the NAS is to be able to shut down the pc, so it sort of kills the benefits...
B! - pofraniAspirantHi All - HELP please!
When i paste a magnet link in and add it to transmission of my readynas duo, it just shows:
(NAME OF FILE)
Downloading from 0 of 0 peers
Magnetized transfer - retrieving metadata (0.00%)
and that's it - it doesn't do anything! it used to work before but for some reason it wont work now.
i have done the port forward but when i check on canyouseeme.org, it shows Connection Refused. I have read tho that this will show closed until the service is actually using the port.
anyway, i have installed utorrent on my pc and that's working fine... so i do not know what is stopping my transmission from working!
please help! - UA22PlumberAspirantI have 2.42 on my Dou and I have been having a problem were transmission stops reporting to the tracker. It went a week before I realized I wasn't getting any upload credit. I stopped transmission, restarted the NAS and restarted transmission(like it restarts easy...) it is now working again. This is the second time that it stopped reporting upload credit to the tracker. Anyone else having this problem? Is there a fix? How about an update for the Sparc users...
- pofraniAspirantI have done a search and other people are having problems with this port closed message but no one's actually chimed in to help. even the publisher has ignored it and just kept updating the other versions apart from the sparc version :(
- JarnoGGuideThere hasn't been an update for the sparc nasses because the Duo super-poussin used to test them died. I'm afraid you'll have to wait till he has some replacement for it.
About the ports, you should check if your router is forwarding it to the correct IP. If you are using upnp to get the port forwarding, you should check if upnp is turned on on your router and if your nas is supplying it with the right IP to forward to. If you manually set the port forwarding on your router, make sure the IP of your nas does not change.
About the magnet links, I've noticed that sometimes it takes a really long time before it starts downloading, especially if there aren't a lot of seeds. At one case it took several hours before it started. - danielvegas1Aspirant
UA22Plumber wrote: I have 2.42 on my Dou and I have been having a problem were transmission stops reporting to the tracker.
I experience the same issue. It's always one specific tracker that loses the connection and I couldn't reproduce the issue yet. For a couple of weeks it has been running okay though.
