gabbano's avatar
gabbano
NewCS on ReadyNAS DUO!
Hi all,
I dont know if this is the right place to post but...
I managed to get my hands on a NewCS verision compiled for ReadyNas. It seems to be working all right exept the Kernel for ReadyNAS does not have "Serial Device Convertor" compiled so my Phoenix USB readers never get mapped to tty\USB\x .
I have read in some forums and it seems to be 2 missing for this to work.
usbserial
ftdi_sio
Someone know how to compile these files for the ReadyNas, someone know where to find information about this?
  • I'm going crazy here....
    I'm by no means a Linux Pro, but damnit how hard can it be?
    I thought getting the cardreader (Phoenix from AD Teknik Sweden) to work was gonna be the problem. But no. All that worked like a charm. I get the mods in there, loading and all is fine, and I see the reader (I think) when I do: dmesg
    It's starting the damn thing that is the problem.
    No matter how I copy newcs to my NAS (Tried both simply tranfering from Windows Explorer to /Media and also WinSPC to Root) the file seems to be faulty?
    I copy the file newcs.readynas to my: /use/local/bin
    did all the chmodding: chmod 775 newcs
    and when I try to start it with:
    ./newcs -c newcs.xml
    I always get:
    -bash: newcs: cannot execute binary file
    Woot? It's working for everbody else? Any ideas? Going mad here. It's the binary from 1.67 RC1.zip, and I'm using the newcs.readynas - file, which should be the file for my ReadNas NV+.
    HEEEEEEEEEEEEEeeeeeeeeeeeeeeeeeeeeeeelp!!!! plz
    What is wrong?
  • Hi All,
    I have a problem . Need install newcs on readynas duo (RAIDiator 4.1.8). I installed succesfull usbserial.ko and ftdi_sio.ko from this links:
    http://www.readynas.com/download/modules/ftdi_sio.ko
    http://www.readynas.com/download/modules/usbserial.ko
    and this links "- Download newcs_readynas.rar from http://rapidshare.com/files/191283875/newcs_readynas.rar.html (direct link)" - not work.
    Please, if anybody have working newcs for readynas duo send me PM or link.
    Thx
    PS. sorry for my english
  • Hello!!
    Based on information in this forum I make oscam compilation for SPARC architecture :D my last compilation:
    https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn9092-sparc-linux
    Unix starttime: 1386884940
    Starttime: 12.12.2013 22:49:00
    Version: oscam-1.20-unstable_svn-r9092
    ConfigDir: /usr/local/bin/
    Web interface support: yes
    Touch interface support: yes
    SSL support: no
    DVB API support: yes
    DVB API with AZBOX support: no
    DVB API with MCA support: no
    DVB API with COOLAPI support: no
    DVB API with STAPI support: no
    Anti-cascading support: yes
    Irdeto guessing: yes
    Debug mode: yes
    Monitor: yes
    Loadbalancing support: yes
    CW Cycle Check support: yes
    LCD support: no
    LED support: no
    IPv6 support: no
    Cache exchange support: yes
    camd 3.3x: no
    camd 3.5 UDP: no
    camd 3.5 TCP: no
    newcamd: yes
    CCcam: yes
    CCcam share: yes
    Pandora: no
    ghttp: yes
    gbox: no
    radegast: no
    serial: yes
    constant CW: yes
    Reader support: yes
    Nagra: yes
    Irdeto: yes
    Conax: yes
    Cryptoworks: yes
    Seca: yes
    Viaccess: yes
    NDS Videoguard: yes
    DRE Crypt: yes
    TONGFANG: yes
    Bulcrypt: yes
    Griffin: yes
    DGCrypt: yes
    cardreader_phoenix: yes
    cardreader_internal_azbox: no
    cardreader_internal_coolapi: no
    cardreader_internal_sci: yes
    cardreader_sc8in1: no
    cardreader_mp35: no
    cardreader_smargo: no
    cardreader_pcsc: no
    cardreader_smartreader: no
    cardreader_db2com: no
    cardreader_stapi: no
    cardreader_stinger: yes
    and some older:
    https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn7157-sparc-linux
    https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn7173-sparc-linux
    https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn7184-sparc-linux
    https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn7750-sparc-linux
    https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn8377-sparc-linux
    https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn8699-sparc-linux
    https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn8821-sparc-linux
    https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn8988-sparc-linux
    Runing script (put in /var/spool/frontview/boot)
    02_rs232_usb_oscam
    #!/bin/sh
    #/var/spool/frontview/boot albo zmienin na start.sh i uruchamiaj z reki
    /sbin/insmod /usr/local/bin/usbserial.ko
    /sbin/insmod /usr/local/bin/pl2303.ko
    #/sbin/insmod /usr/local/bin/ftdi_sio.ko
    sleep 3
    #/usr/local/bin/newcs -C /usr/local/bin/newcs_phoenix.xml
    /usr/local/bin/oscam -b -c /usr/local/bin/
    Somtime I put SPARC compilation with other on pkteam.pl (sh4/arm/mips).
    Regards
    zukon/PKT
  • Actual compilation:
    https://dl.dropboxusercontent.com/u/86095873/oscam/oscam-1.20-unstable_svn9676-sparc-linux
    Unix starttime: 1398373491
    Starttime: 24.04.2014 23:04:51
    Version: oscam-1.20-unstable_svn-r9676
    Compiler: sparc-linux
    LiveLog support: yes
    jQuery support intern: yes
    SSL support: no
    DVB API with Samsung TV support: no
    Debug mode: yes
    Monitor: yes
    LCD support: no
    LED support: no
    IPv6 support: no
    Clockfix with realtime clock: yes
    camd 3.3x: no
    camd 3.5 UDP: no
    camd 3.5 TCP: no
    newcamd: yes
    CCcam: yes
    CCcam share: yes
    Pandora: no
    ghttp: yes
    gbox: no
    radegast: no
    serial: yes
    constant CW: yes
    Reader support: yes
    Nagra: yes
    Irdeto: yes
    Conax: yes
    Cryptoworks: yes
    Seca: yes
    Viaccess: yes
    NDS Videoguard: yes
    DRE Crypt: yes
    TONGFANG: yes
    Bulcrypt: yes
    Griffin: yes
    DGCrypt: yes
    cardreader_mp35: no
    cardreader_pcsc: no
    Regards
    zukon/PKT
  • I Need the files plus the modules for my 516, please help
ProSupport for Business
