soremaniac
Apr 19, 2020Aspirant
No Web Interface - Frontview gone ;-( on my ReadyNAS Pro
Okay I shut have read until the end*, but I dit not. I (tryed) to install Pi-Hole on my ReadyNAS PRO with 6.9.6 (*= Pi-Hole Web Interface also uses http://ip-nas.local/admin -> yes realy BAD!) So...
Apr 24, 2020Guru - Experienced User
soremaniac wrote:
and when nothing happens? in that folder...(on the LED Panel show's that the drive is connectet)
Well, of course your NAS software is broken at the moment. It's not clear to me if that is limited to the web interface, or if it is also affecting the readynas application itself, Normally the NAS will automatically mount the USB to /media when you connect it.
Even if that isn't happening, you should see the disk in /dev/disk/by-id. Have you looked there for it?
soremaniac
Apr 24, 2020Aspirant
yes found it there...
- StephenBApr 24, 2020Guru - Experienced User
Good. The next step is to figure out how to mount it. How is if formated? Are you seeing it in /dev?
- soremaniacApr 26, 2020Aspirant
The extern Disk is a Sandisk Extrem -> USB Externes physisches Volume • ExFAT (no encription)
and in the /dev it is as in the pic under /dev/disk/external/3:1:Extreme_SSD:3......
(under MacOS it mounts "Extreme SSD" no _(underscore))
As much i knwo it shut mout just...
thx for your help
- StephenBApr 26, 2020Guru - Experienced User
The NAS doesn't support exfat. You can use fat32, ext, btrfs, or ntfs.
- soremaniacApr 27, 2020Aspirant
now it does (and mounts the drive:-D) -> see the pic
Open your terminal and install the exfat-fuse and exfat-utils packages using the following commands:
sudo apt update
sudo apt install exfat-fuse exfat-utilssee here: https://linuxize.com/post/how-to-mount-an-exfat-drive-on-debian/
and next thing is backUP...
and now copying all the DATA in Terminal with the Comand:
https://askubuntu.com/questions/195983/how-to-copy-files-via-terminal
cp -Ri OwnCloud/ /media/USB_HDD_1/
cp -Ri Musik/ /media/USB_HDD_1/
cp -Ri Videos/ /media/USB_HDD_1/
and so on.... :-)
and it WORKS :-) sorry "eifach guet"....
Thx
