b1jzcbx
Mar 25, 2022Tutor
nzbget 21.1 stable on os 6.10.7
Hey folks! i have a readynas rndp6000-100nas that i've gone through all the upgrades to (firmware is 2010FLAME6, OS 6.10.7, intel E7600 cpu, and 4GB of DDR2 800). has anyone been able to inst...
b1jzcbx
Apr 07, 2022Tutor
i was wrong.. didn't fix it. i was looking in the wrong place.
my tls issue lies with the news server feeds. Like you, i don't bother with https for regular web gui to my appliances behind my firewall.
however i DO want my connection to the news servers encrypted.. that still doesn't work. i probably have the updated cert somewhere on the box. i ran the lets encrypt update from rnxtras.com so it should be there. it's probably very simple, i'm just very novice at this.
i learned yesterday that nzbget should've been installed in the 'opt' folder; i installed it in the 'apps' folder because that's where readynas OS installs it's apps. i'm trying to keep this as close to the vanilla debian/linux install as possible.
Apr 07, 2022Guru - Experienced User
Be very careful here. The entire OS partition is only 4 GB, and very bad things happen when it gets full.
The ReadyNAS apps folder is a mount point to the data volume (/data/.apps in a ReadyNAS using XRAID). So installing to /apps eliminates the possibility that the app will end up filling the OS file system.
One alternative possibility is to create a soft link in /opt that points to /data/.apps/<folder>. You can do this after the initial install - just move the /opts folder to /apps, and then create a link with the same name as the original folder.
- b1jzcbxApr 07, 2022Tutor
ok this is new to me.
when i ssh in and drill down to the root and do an 'ls' it shows the usual folders (bin, etc, home, yadda yadda), plus the two volumes that i have my drives set up as (Vol1 and Vol2), plus the 'Apps' directory, where the default packages available to me would be installed had i gone through the default package manager.
you're saying that the apps folder is really just a shortcut to a folder in the data directory? sorry, this is the first time i'm being told theres such a thing called a 'mount point'.
thanks for chiming in!
- ipb_ukApr 07, 2022Aspirant
Can you do a ls -l in the apps directory? is nzbget list, if so do the same in it's folder.
What do you see?
- StephenBApr 07, 2022Guru - Experienced User
If you run mount, you can see this. There are a lot of mounts on the ReadyNAS, so I used grep to only show the one of interest.
root@NAS:~# mount | grep -i app /dev/md127 on /apps type btrfs (rw,noatime,nodiratime,nospace_cache,subvolid=258,subvol=/.apps) root@NAS:~#md127 is the RAID array (think of it as a virtual disk) for my data volume. So /data/.apps is being mounted on /apps.
This isn't quite the same as a shortcut. There is an empty placeholder folder called /apps in the OS partition. That empty placeholder is the "mount point". The OS mounts /data/.apps "over" that folder as part of the boot process.
There is a brief sketch of the concept here: https://opensource.com/life/16/10/introduction-linux-filesystems (scroll down to the "Mounting section).
Filesystems are mounted on an existing directory/mount point using the mount command. In general, any directory that is used as a mount point should be empty and not have any other files contained in it. Linux will not prevent users from mounting one filesystem over one that is already there or on a directory that contains files. If you mount a filesystem on an existing directory or filesystem, the original contents will be hidden and only the content of the newly mounted filesystem will be visible.
Note you can remount the OS to /mnt using this command:
# mount --bind / /mntWhen you do this, exploring /mnt lets you examine the root file system without the mounts getting in the way. So if you enter ls -l /mnt/apps, you will see it is empty.
root@NAS:~# ls -als /mnt/apps total 16 0 drwxrwxr-x 1 admin admin 0 Mar 7 2017 . 16 drwxr-xr-x 1 root root 260 Apr 7 00:05 .. root@NAS:~#BTW, if you do try this, you undo it by
# cd // # umount /mntThe umount will fail if you are inside /mnt - the cd // ensures that is not the case.
- b1jzcbxApr 11, 2022Tutor
well I'm VERY glad you pointed the facets of the apps folder out to me. thank you! saves me a whole lotta headache!
so i guess i'll just leave it as is. when i set up the nas, i did everything as root, including the letsencrypt update from rnxtras. then i created my 2 volumes. the last thing i did was create additional user accounts. basically, i get it all running and updated first before installing additional software and users.
thanks!
