viperhansa
Sep 10, 2016Virtuoso
NZBGet general....
Hi all... Since it seems that whocares is not updating anything anymore (?) it would be very nice if someone could update or make an autoupdate version of nzbget. The one in apps by readynas gur...
jhagg
Sep 12, 2016Luminary
Edit: I provided direrections to my source below but decided I might save a bunch of people some time and effort and just post the package it creates :)
Make sure you have backed up NZBget settings and enjoy 17.1 hot off the presses.
If you follow THIS guide, you will be able to update your existing ReadyNAS NZBGet package to the latest, which is as of today 17.1.
Use the first option when he gives you 2 (the second option is for a testing version) and replace text in 2 areas that says 16.4 with 17.1.
You will be good to go if you follow this to the letter I have done it several times.
Let me know if you run into any trouble!
viperhansa
Sep 12, 2016Virtuoso
So, jhagg, i just upload NZBGet 17.1 (jhagg) and i'm done?
And for next update i can follow the instructions linked?
Regards and thanks!
// Hans
- jhaggSep 12, 2016Luminary
Correct, just upload the file in apps frontview and you are all set.
Yes for future updates you would need to repackage the updates per Richard's instructions, pay attention to the release version number and replace as approriate. (18.0 is currently in development so you would just swap 17.1 with 18.0 as needed when its released.
- viperhansaSep 12, 2016Virtuoso
hi again! :-)
Well, spoke too early.... System: Cannot install application nzbget-app_1.0.4_all-17.1.deb.
I have whocares version installed... rndxtras...
The one in "app store" nzbget is another...
ideas?
// Hans
Do this first:
1) Backup NZBGet App settings and uninstall it from ReadyNAS Admin Web UI
