viperhansa
Sep 10, 2016Virtuoso
NZBGet general....
Hi all... Since it seems that whocares is not updating anything anymore (?) it would be very nice if someone could update or make an autoupdate version of nzbget. The one in apps by readynas gur...
viperhansa
Sep 12, 2016Virtuoso
So, jhagg, i just upload NZBGet 17.1 (jhagg) and i'm done?
And for next update i can follow the instructions linked?
Regards and thanks!
// Hans
jhagg
Sep 12, 2016Luminary
Correct, just upload the file in apps frontview and you are all set.
Yes for future updates you would need to repackage the updates per Richard's instructions, pay attention to the release version number and replace as approriate. (18.0 is currently in development so you would just swap 17.1 with 18.0 as needed when its released.
- viperhansaSep 12, 2016Virtuoso
hi again! :-)
Well, spoke too early.... System: Cannot install application nzbget-app_1.0.4_all-17.1.deb.
I have whocares version installed... rndxtras...
The one in "app store" nzbget is another...
ideas?
// Hans
- jhaggSep 12, 2016Luminary
Do this first:
1) Backup NZBGet App settings and uninstall it from ReadyNAS Admin Web UI
I would move to the app store version. I have tried getting support from whocares rnxtras with zero luck. I even requested a refund on a non working app and was ignored.
This version works perfectly and is easy to update yourself.
Well, For me personally there where no problem earlier with whocares.. I think he has alot to do and are overworked.
I will try this later, have a quite buzzy week ahed..
Thanks for the help and ideas!
