canprof
Oct 04, 2012Aspirant
PC App for ReadyNAS Duo
I am using ReadyNAS Duo, firmware 4.1.10. Photos II (v2.2) is installed according to the add-ons page, but I have no idea how to access it. Is there an app for the PC I need to install? If I click ...
Oct 05, 2012Guru - Experienced User
Not sure how you installed it, but photos II is not available for the Duo V1 products (which you have if you are running 4.1.10).
Is it possible that you installed photos 1? If so, that doesn't work anymore.
