jfkcom
May 25, 2014Aspirant
PHP5 problems with addons PHP5-GD and Mediawiki
Hi, some weeks ago I upgraded my ReadyNAS Ultra 6 to Raidiator 4.2.25. Before, my addons PHP5-GD v1.8 and Mediawiki v1.0 worked. After upgrading unfortunately I tried to install some additional php-s...
jfkcom
May 30, 2014Aspirant
Meanwhile, I upgraded to Raidiator 4.2.26. Here is the output of dpkg-query -l '*php*':
Is libapache2-mod-php5 obsolete? And what is an appropriate replacement for me? Any help appreciated.
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Cfg-files/Unpacked/Failed-cfg/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Hold/Reinst-required/X=both-problems (Status,Err: uppercase=bad)
||/ Name Version Description
un libapache2-mod-php4 <none> (no description available)
un libapache2-mod-php5 <none> (no description available)
ii libphp-adodb 4.93a-1.1 The 'adodb' database abstraction layer for php
un php-auth-sasl <none> (no description available)
ii php-net-smtp 1.2.6-2 PHP PEAR module implementing SMTP protocol
ii php-net-socket 1.0.6-2 PHP PEAR Network Socket Interface module
ii php-pear 5.2.0+dfsg-8+etch16 PEAR - PHP Extension and Application Repository
un php3 <none> (no description available)
un php4 <none> (no description available)
un php4-cli <none> (no description available)
un php4-dev <none> (no description available)
un php4-mysql <none> (no description available)
un php4-odbc <none> (no description available)
un php4-pear <none> (no description available)
un php4-pgsql <none> (no description available)
un php4-sybase <none> (no description available)
un php5 <none> (no description available)
ii php5-cli 5.2.0+dfsg-8+etch16 command-line interpreter for the php5 scripting language
ii php5-common 5.2.0+dfsg-8+etch16 Common files for packages built from the php5 source
ii php5-curl 5.2.0+dfsg-8+etch16 CURL module for php5
un php5-dev <none> (no description available)
ii php5-gd 5.2.0+dfsg-8+etch16 GD module for php5
ii php5-mcrypt 5.2.0+dfsg-8+etch16 MCrypt module for php5
ii php5-memcache 2.0.1-1.1 memcache extension module for PHP5
ii php5-mhash 5.2.0+dfsg-8+etch16 MHASH module for php5
ii php5-mysql 5.2.0+dfsg-8+etch16 MySQL module for php5
un php5-mysqli <none> (no description available)
un php5-odbc <none> (no description available)
un php5-pgsql <none> (no description available)
ii php5-pspell 5.2.0+dfsg-8+etch16 pspell module for php5
ii php5-snmp 5.2.0+dfsg-8+etch16 SNMP module for php5
ii php5-sqlite 5.2.0+dfsg-8+etch16 SQLite module for php5
un php5-sybase <none> (no description available)
ii php5-xmlrpc 5.2.0+dfsg-8+etch16 XML-RPC module for php5
ii php5-xsl 5.2.0+dfsg-8+etch16 XSL module for php5
un phpapi-20060613+lfs <none> (no description available)
