jfkcom
May 25, 2014Aspirant
PHP5 problems with addons PHP5-GD and Mediawiki
Hi, some weeks ago I upgraded my ReadyNAS Ultra 6 to Raidiator 4.2.25. Before, my addons PHP5-GD v1.8 and Mediawiki v1.0 worked. After upgrading unfortunately I tried to install some additional php-s...
mdgm-ntgr
Sep 05, 2014NETGEAR Employee Retired
When a thread has been inactive for a while we assume it is solved.
Installing an add-on over the top of itself may help, but I think the old PHP add-ons aren't compatible with the latest firmware or don't work well with it.
Have you consider the PHP add-on here?: https://rnxtras.com/addons/php-5-4-readynas-4-x86
I think considering the mess that has been made it could be best if you backup your data, do a factory default (wipes all data, settings, everything) and restore your data from backup.
