mode500's avatar
mode500
PhpMyAdmin & MysqlOn Problems
Hi all :D
This is my first post here so go easy with me ...
OK I've recently bought a second hand ReadyNAS Duo V1 and am trying to get it up & running as a web server to use wordpress on. I have read plenty of info on the subject and followed a couple of guides to the best of my ability but have come across the problem of not being able to log into PhpMyAdmin due to the Username & Password that is highly discussed elsewhere on the web.
Now my question is, when it says 'Edit the file config.inc.php' where exactly am I supposed to be looking for this file to edit? I have searched high & low for an answer to this but to no avail. I'm along the lines of thinking that it maybe something to do in Front View under the MysqlOn option which brings me to my second question, although its more of a query. In Front View MysqlOn is on and up & running but the inner box shows no content at all, is this correct? Its just that the PHP5 & PHPMyAdmin have content in their inner boxes but the MysqlOn is completely blank. This I found to be a little odd.
MysqlOn V.1.0
PHP5 V.5.3.28-sparc-4.5.5
PHPMyAdmin V.2.5
RAIDiator V.4.1.13 [1.00a043]
RAIDar V.4.3.8 ( 4.3.8 )
Mac OS X 10.4.9
Oh, and I also d/l a copy of iTerm if that helps!
Many thanks in advance :)
  • & under Frontview I have Website AFP, backup NSF & AFP, media AFP & webroot non shares set up.
  • StephenB wrote:
    Ok. Are you sure you are actually logged into the NAS with both iterm and terminal???
    For instance, if you enter
    cd /c
    ls -l
    do you see the shared folders on the NAS
    I'm sorry but when you say do I see the shared folders on the NAS am I actually looking on the NAS or do you mean in either Terminal or iTerm!?!
    On the NAS itself I see : admin backup homes media & Website folders but no shares
  • StephenB's avatar
    backup and media are shares that were created by default.
    "cd /c" should navigate you to the NAS data volume
    "ls -l" does a listing of the contents of the folder you are in.
    So when you type "ls -l" in terminal and iterm, you should see a list of files in response. That list should include the shared folders you created on the NAS, because you should have navigated into the NAS data volume. If you aren't seeing that list, then you are doing something wrong. It's hard to know exactly what, since I don't know how you are launching terminal and iterm (and I'm not a mac guy anyway).
  • Yeah I am seeing nothing at all ... Is it something to do with the fact that I don't have any webroot shares turned on!?!
  • StephenB's avatar
    No.
    Most likely you aren't really logged into the NAS with either iterm or terminal. ls -al would return something.
    There is a guide for terminal with ssh here: https://www.youtube.com/watch?v=J_8ZsXP1EYk
  • StephenB wrote:
    No.
    Many thanks for that although it appears I can't even do the first thing that he suggests as I am getting 'Linux NAS 2.6.17.14ReadyNAS #1 Wed Jun 20 20:08:20 PDT 2012 padre unknown
    Connection to n.umb.e.r closed.
    [Process completed]
    What the hell is wrong with my NAS in terms of this, I just seem to be able to connect to it at all in this sense!
  • OK I think I am logged in now and this is what I get :
    NAStronaut:~# ls -lcd /c
    drwxrwxrwx 9 root root 16384 Sep 16 19:06 /c
    NAStronaut:~# ls -l
    total 16
    -rw-r--r-- 1 root root 9079 Sep 18 01:16 GRANT
    NAStronaut:~#
    Although I still don't see any files or folders
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    That shows your GRANT share.
    To see the contents of the GRANT share you could do e.g.
    # ls -la /c/GRANT
    or look recursively using e.g.
    # ls -laR /c
    # ls -la /c/GRANT
    # ls -laR /c
    Woohoo!!! FINALLY got somewhere with the second command and it brought up this amongst other things :
    /c/webroot:
    total 48
    drwxr-xr-x 3 admin admin 16384 Sep 7 2008 .
    drwxrwxrwx 9 root root 16384 Sep 7 2008 ..
    drwxr-xr-x 11 admin admin 16384 Dec 15 2010 phpadm
    /c/webroot/phpadm:
    total 2608
    drwxr-xr-x 11 admin admin 16384 Dec 15 2010 .
    drwxr-xr-x 3 admin admin 16384 Sep 7 2008 ..
    -rw-r--r-- 1 admin admin 10829 Nov 29 2010 browse_foreigners.php
    -rw-r--r-- 1 admin admin 4354 Nov 29 2010 bs_change_mime_type.php
    -rw-r--r-- 1 admin admin 1797 Nov 29 2010 bs_disp_as_mime_type.php
    -rw-r--r-- 1 admin admin 2368 Nov 29 2010 bs_play_media.php
    -rw-r--r-- 1 admin admin 798 Nov 29 2010 calendar.php
    -rw-r--r-- 1 admin admin 11519 Nov 29 2010 ChangeLog
    -rw-r--r-- 1 admin admin 3565 Nov 29 2010 changelog.php
    -rw-r--r-- 1 admin admin 473 Nov 29 2010 chk_rel.php
    -rw-r--r-- 1 admin admin 1854 Dec 15 2010 config.inc.php
    -rw-r--r-- 1 admin admin 2162 Nov 29 2010 config.sample.inc.php
    drwxr-xr-x 3 admin admin 16384 Nov 29 2010 contrib
    -rw-r--r-- 1 admin admin 234 Nov 29 2010 CREDITS
    -rw-r--r-- 1 admin admin 1458 Nov 29 2010 db_create.php
    -rw-r--r-- 1 admin admin 10415 Nov 29 2010 db_datadict.php
    -rw-r--r-- 1 admin admin 2336 Nov 29 2010 db_export.php
    -rw-r--r-- 1 admin admin 537 Nov 29 2010 db_import.php
    -rw-r--r-- 1 admin admin 27435 Nov 29 2010 db_operations.php
    -rw-r--r-- 1 admin admin 7389 Nov 29 2010 db_printview.php
    -rw-r--r-- 1 admin admin 30581 Nov 29 2010 db_qbe.php
    -rw-r--r-- 1 admin admin 13120 Nov 29 2010 db_search.php
    -rw-r--r-- 1 admin admin 980 Nov 29 2010 db_sql.php
    -rw-r--r-- 1 admin admin 25353 Nov 29 2010 db_structure.php
    -rw-r--r-- 1 admin admin 7277 Nov 29 2010 db_tracking.php
    -rw-r--r-- 1 admin admin 3404 Nov 29 2010 docs.css
    drwxr-xr-x 3 admin admin 16384 Nov 29 2010 documentation-gsoc
    -rw-r--r-- 1 admin admin 246242 Nov 29 2010 Documentation.html
    -rw-r--r-- 1 admin admin 173318 Nov 29 2010 Documentation.txt
    -rw-r--r-- 1 admin admin 2243 Nov 29 2010 error.php
    -rw-r--r-- 1 admin admin 25308 Nov 29 2010 export.php
    -rw-r--r-- 1 admin admin 18902 Nov 29 2010 favicon.ico
    -rw-r--r-- 1 admin admin 15614 Nov 29 2010 import.php
    -rw-r--r-- 1 admin admin 1077 Nov 29 2010 import_status.php
    -rw-r--r-- 1 admin admin 6789 Nov 29 2010 index.php
    -rw-r--r-- 1 admin admin 137 Nov 29 2010 INSTALL
    drwxr-xr-x 3 admin admin 16384 Nov 29 2010 js
    drwxr-xr-x 2 admin admin 16384 Nov 29 2010 lang
    drwxr-xr-x 11 admin admin 16384 Nov 29 2010 libraries
    -rw-r--r-- 1 admin admin 18011 Nov 29 2010 LICENSE
    -rw-r--r-- 1 admin admin 453 Nov 29 2010 license.php
    -rw-r--r-- 1 admin admin 13369 Nov 29 2010 main.php
    -rw-r--r-- 1 admin admin 27220 Nov 29 2010 navigation.php
    -rw-r--r-- 1 admin admin 27617 Nov 29 2010 pdf_pages.php
    -rw-r--r-- 1 admin admin 53336 Nov 29 2010 pdf_schema.php
    -rw-r--r-- 1 admin admin 421 Nov 29 2010 phpinfo.php
    -rw-r--r-- 1 admin admin 1079 Nov 29 2010 phpmyadmin.css.php
    drwxr-xr-x 5 admin admin 16384 Nov 29 2010 pmd
    -rw-r--r-- 1 admin admin 9845 Nov 29 2010 pmd_common.php
    -rw-r--r-- 1 admin admin 1866 Nov 29 2010 pmd_display_field.php
    -rw-r--r-- 1 admin admin 18504 Nov 29 2010 pmd_general.php
    -rw-r--r-- 1 admin admin 829 Nov 29 2010 pmd_help.php
    -rw-r--r-- 1 admin admin 3762 Nov 29 2010 pmd_pdf.php
    -rw-r--r-- 1 admin admin 3994 Nov 29 2010 pmd_relation_new.php
    -rw-r--r-- 1 admin admin 1973 Nov 29 2010 pmd_relation_upd.php
    -rw-r--r-- 1 admin admin 2071 Nov 29 2010 pmd_save_pos.php
    -rw-r--r-- 1 admin admin 1063 Nov 29 2010 print.css
    -rw-r--r-- 1 admin admin 8252 Nov 29 2010 querywindow.php
    -rw-r--r-- 1 admin admin 2571 Nov 29 2010 README
    -rw-r--r-- 1 admin admin 758 Nov 29 2010 README.VENDOR
    -rw-r--r-- 1 admin admin 29 Nov 29 2010 RELEASE-DATE-3.3.8.1
    -rw-r--r-- 1 admin admin 26 Nov 29 2010 robots.txt
    drwxr-xr-x 2 admin admin 16384 Nov 29 2010 scripts
    -rw-r--r-- 1 admin admin 7584 Nov 29 2010 server_binlog.php
    -rw-r--r-- 1 admin admin 2641 Nov 29 2010 server_collations.php
    -rw-r--r-- 1 admin admin 15336 Nov 29 2010 server_databases.php
    -rw-r--r-- 1 admin admin 4689 Nov 29 2010 server_engines.php
    -rw-r--r-- 1 admin admin 1615 Nov 29 2010 server_export.php
    -rw-r--r-- 1 admin admin 549 Nov 29 2010 server_import.php
    -rw-r--r-- 1 admin admin 98602 Nov 29 2010 server_privileges.php
    -rw-r--r-- 1 admin admin 2893 Nov 29 2010 server_processlist.php
    -rw-r--r-- 1 admin admin 16986 Nov 29 2010 server_replication.php
    -rw-r--r-- 1 admin admin 565 Nov 29 2010 server_sql.php
    -rw-r--r-- 1 admin admin 22147 Nov 29 2010 server_status.php
    -rw-r--r-- 1 admin admin 59483 Nov 29 2010 server_synchronize.php
    -rw-r--r-- 1 admin admin 2196 Nov 29 2010 server_variables.php
    drwxr-xr-x 4 admin admin 16384 Nov 29 2010 setup
    -rw-r--r-- 1 admin admin 297 Nov 29 2010 show_config_errors.php
    -rw-r--r-- 1 admin admin 26786 Nov 29 2010 sql.php
    -rw-r--r-- 1 admin admin 8175 Nov 29 2010 tbl_addfield.php
    -rw-r--r-- 1 admin admin 7214 Nov 29 2010 tbl_alter.php
    -rw-r--r-- 1 admin admin 54171 Nov 29 2010 tbl_change.php
    -rw-r--r-- 1 admin admin 9781 Nov 29 2010 tbl_create.php
    -rw-r--r-- 1 admin admin 2573 Nov 29 2010 tbl_export.php
    -rw-r--r-- 1 admin admin 700 Nov 29 2010 tbl_import.php
    -rw-r--r-- 1 admin admin 7954 Nov 29 2010 tbl_indexes.php
    -rw-r--r-- 1 admin admin 2435 Nov 29 2010 tbl_move_copy.php
    -rw-r--r-- 1 admin admin 28458 Nov 29 2010 tbl_operations.php
    -rw-r--r-- 1 admin admin 16521 Nov 29 2010 tbl_printview.php
    -rw-r--r-- 1 admin admin 23511 Nov 29 2010 tbl_relation.php
    -rw-r--r-- 1 admin admin 15613 Nov 29 2010 tbl_replace.php
    -rw-r--r-- 1 admin admin 4825 Nov 29 2010 tbl_row_action.php
    -rw-r--r-- 1 admin admin 16239 Nov 29 2010 tbl_select.php
    -rw-r--r-- 1 admin admin 919 Nov 29 2010 tbl_sql.php
    -rw-r--r-- 1 admin admin 31967 Nov 29 2010 tbl_structure.php
    -rw-r--r-- 1 admin admin 25306 Nov 29 2010 tbl_tracking.php
    drwxr-xr-x 4 admin admin 16384 Nov 29 2010 themes
    -rw-r--r-- 1 admin admin 1253 Nov 29 2010 themes.php
    -rw-r--r-- 1 admin admin 196 Nov 29 2010 TODO
    -rw-r--r-- 1 admin admin 1625 Nov 29 2010 transformation_overview.php
    -rw-r--r-- 1 admin admin 3674 Nov 29 2010 transformation_wrapper.php
    -rw-r--r-- 1 admin admin 9076 Nov 29 2010 translators.html
    -rw-r--r-- 1 admin admin 4569 Nov 29 2010 user_password.php
    -rw-r--r-- 1 admin admin 5368 Nov 29 2010 view_create.php
    -rw-r--r-- 1 admin admin 1132 Nov 29 2010 webapp.php
ProSupport for Business
