Uodesjo
Jan 02, 2012Aspirant
PhpMyAdmin 3.4.5 for Sparc
Hi I bought the bundle with PHP 5.3.8 and PhpMyAdmin 3.4.8 (Bundle description says 3.4.8 but it is 3.4.5) and installed them on my Duo. http://readynasxtras.com/readynas-sparc-add-ons/bundles-spar...
InTheShires
Jan 02, 2012Tutor
Have you re-installed the PHP5 addon?
Search the board here, and Stefan's site (WhoCares?) for his posts explaining how to try certain things to try get it working. Specific reinstall/remove order, and other tips. He helped me when I had errors with phpMA, but I'd already gone through most, if not all of his suggestions on solving the problem I was having. My issue was obviously a PEBCAK variant, because he remoted in, did everything I'd already done, it worked first time! :?
PEBCAK = ProblemExistedBetweenChairAndKeyboard. :oops:
I'll have a quick search later for the posts of his I'm thinking of...
Ok, shortedned breakdown.
And. http://readynasxtras.com/readynas-x86-a ... yadmin-x86
MySQL is ON.
Tried different browsers, caches cleared. (Firefix and Opera)
PhP5 (yours) reinstalled.
Removed PHPMA, reboot, install PHPMA.
or
Remove PHP5. Reboot. Install php5.
Reinstall PHPMA.
