Uodesjo
Jan 02, 2012Aspirant
PhpMyAdmin 3.4.5 for Sparc
Hi I bought the bundle with PHP 5.3.8 and PhpMyAdmin 3.4.8 (Bundle description says 3.4.8 but it is 3.4.5) and installed them on my Duo. http://readynasxtras.com/readynas-sparc-add-ons/bundles-spar...
Uodesjo
Jan 03, 2012Aspirant
InTheShires wrote: Have you re-installed the PHP5 addon?
Search the board here, and Stefan's site (WhoCares?) for his posts explaining how to try certain things to try get it working. Specific reinstall/remove order, and other tips. He helped me when I had errors with phpMA, but I'd already gone through most, if not all of his suggestions on solving the problem I was having. My issue was obviously a PEBCAK variant, because he remoted in, did everything I'd already done, it worked first time! :?
PEBCAK = ProblemExistedBetweenChairAndKeyboard. :oops:
I'll have a quick search later for the posts of his I'm thinking of...
Ok, shortedned breakdown.
MySQL is ON.
Tried different browsers, caches cleared. (Firefix and Opera)
PhP5 (yours) reinstalled.
Removed PHPMA, reboot, install PHPMA.
or
Remove PHP5. Reboot. Install php5.
Reinstall PHPMA.
And. http://readynasxtras.com/readynas-x86-add-ons/phpmyadmin-x86
Thanks.
I just re-installed PHP5 and that was the trick. At least i don't get the same error anymore. Now I will start to investigate and see how it works.
Thanks again
/U
