axg20202
Apr 16, 2013Aspirant
PIWIGO setup?
I've just downloaded (paid for) this add-on only to discover that there are zero installation instructions provided. The Piwigo website instructions don't seem to be relevant as they assume you will b...
axg20202
May 08, 2013Aspirant
super-poussin wrote: to set ip up simply click on the launch button , you will have setup page
database is piwigo
database user is root without password
Those info should be on genie, they are not ?
Well, that's two of the installation entries, what about the rest? I tried these and it just says cannot connect to server. Should it be set to localhost? Honestly, I appreciate your hard work S-P but what is the point in providing an add-on with zero instructions on how to get started with it? Please, can you post the setup instructions here in full?
And, again, dear Netgear, your Genie service sucks the sweat from a dead dogs balls.....easily the most annoying, outdated, slow and generally cheap-ass e-commerce system I have used in the last 10 years of using the internet. Get it together for Pete's sake.
- Aug 18, 2018Retired_Member
