axg20202
Apr 16, 2013Aspirant
PIWIGO setup?
I've just downloaded (paid for) this add-on only to discover that there are zero installation instructions provided. The Piwigo website instructions don't seem to be relevant as they assume you will b...
super_poussin
May 08, 2013Virtuoso
Piwigo For R6 :
Port used is : 7091 for http
https access can be used : https://localhost/apps/piwigo/index.php
By default database created at install step is piwigo
Mysql user is root without password
for the rest it follow Piwigo statndard installation process
- Aug 18, 2018Retired_Member
