axg20202
Apr 16, 2013Aspirant
PIWIGO setup?
I've just downloaded (paid for) this add-on only to discover that there are zero installation instructions provided. The Piwigo website instructions don't seem to be relevant as they assume you will b...
axg20202
May 09, 2013Aspirant
Thanks. So does that mean I simply enter "localhost" in the Host field, root for the username, blank password and database name, and then any entries I like for webmaster username and password etc? If so, I still get a Cannot connect to server message. I am trying to access it inside my LAN, so I should not have to use any port forwarding etc yet.
- Aug 18, 2018Retired_Member
