cat509
May 30, 2013Tutor
Plex question
Would someone be able to tell me where the Preferences.xml for Plex is located? I'm using readynas os6. Thank you!
cat509
May 30, 2013Tutor
Govnah,
Thank you!! When I try to cd \ into that directory though it says that the Plex Media Server directory doesn't exist. I think I have stopped the server with the ctl stop etc. When I do a ls Plex Media Server is in the MediaLibrary. Any suggestions or instructions?
