cat509
May 30, 2013Tutor
Plex question
Would someone be able to tell me where the Preferences.xml for Plex is located? I'm using readynas os6. Thank you!
btaroli
May 31, 2013Prodigy
Well, I see your profile says you're using a Duo... runs very different OS than the RN516 that Govnah is using. The base path for 4.x (and as far as I know 5.x) OS'es is /c/.plex/
On my Pro 6 (4.2.22), I found it at /c/.plex/Library/Application Support/Plex Media Server/Preferences.xml
Indeed, on my RN516 (6.0.6), I did find it at /apps/plexmediaserver/MediaLibrary/Plex Media Server/Preferences.xml
