cat509
May 30, 2013Tutor
Plex question
Would someone be able to tell me where the Preferences.xml for Plex is located? I'm using readynas os6. Thank you!
cat509
May 31, 2013Tutor
btaroli have a new 312 that runs os 6. I forgot to change that in my profile. But it was exactly where you said it would be. Thanks again for your help!
mdgm thank you for your help as well. Your line did the trick. I was able to edit my Preferences.xml and now can get in to my Plex Media Server again.
Thanks again for everyone's help!!
