dgerson76
Mar 06, 2012Aspirant
Plex servers unavailable - intermittant
I am running a ReadyNas Ultra2+, and have installed the Plex service. Everything runs smooth, with one exception. More often than not, i cannot reach the plex server, either locally or remote. The service appears to be running, but I normally have to stop it and restart the service to get it working. It might work fine for a few days, then nothing.
What is the best way to check and see what is causing it to hang? Let me know if I can post any logs.
thanks
thanks
- mdgm-ntgrNETGEAR Employee RetiredAre you running the latest version?: http://plexapp.com/linux/linux-pms-download.php
- dgerson76AspirantEmbarrassing, no. I was on 9.5.2. Updating now, thanks. I'll post back in a few days to see if it works.
- dgerson76AspirantWell, its happening again. No explanation, it just stops responding. When i stop it in Frontview, it says its already stopped and cant be stopped. Although it still shows green.
Restarting the service fixes it, but i cant find any ideas in logs or anything. - mdgm-ntgrNETGEAR Employee RetiredAre you running this new version of PMS?: http://forums.plexapp.com/index.php/topic/38976-0953309-for-linux/
If not, update to it and it should resolve the issue, I think. - dgerson76AspirantThanks, i will try this. Why dont they update the regular downloads page here:
That is where i normally look for updates.
DG - mdgm-ntgrNETGEAR Employee Retireddgerson76 it looks like they have updated the page with links to beta versions of the add-on in addition to the stable links.
