shpxnvz
Aug 21, 2011Aspirant
Plex transcoding
First, this add-on is great, thanks to the devs for putting it together! It works flawlessly for most audio and for streaming SD video. I'm running into a bit of an issue with transcoding HD video. ...
shpxnvz
Thanks for the heads up. I saw your post too and checked it out on my NAS in case I was having the same problem. In my case it writes to the /tmp directory but never gets above 13% full or so, probably because it's transcoding down to a pretty low resolution so the resulting files are small.
