shpxnvz
Aug 21, 2011Aspirant
Plex transcoding
First, this add-on is great, thanks to the devs for putting it together! It works flawlessly for most audio and for streaming SD video. I'm running into a bit of an issue with transcoding HD video. ...
shpxnvz
Aug 22, 2011Aspirant
Yes indeed! If you find out how to change the temp directory location I'll be doing that too. But at least for now, while transcoding, I've got 67% free space on the root volume, and the transcoded video segments are all under 2MB (the client is a tablet so it's going to a low resolution/bitrate). It chugs along and the utilization of the root volume never changes appreciably.
