nuffodds
Aug 22, 2017Aspirant
Power button is constantly blinking on the Readynas DUO RND2000 v1
The led flashing quickly, then slowly about 16 times the speak bleeps it does this repeatedly. I removed it from one network working and tried to add it to a new one and this is the result. I do...
Aug 22, 2017Guru - Experienced User
The led patterns are here: http://home.bott.ca/webserver/?p=324
You can access the data volume by connecting disk 1 to a Windows PC, and installing r-linux for windows. http://www.r-tt.com/free_linux_recovery/
That might be safer than trying OS reinstall, etc.
