nuffodds
Aug 22, 2017Aspirant
Power button is constantly blinking on the Readynas DUO RND2000 v1
The led flashing quickly, then slowly about 16 times the speak bleeps it does this repeatedly. I removed it from one network working and tried to add it to a new one and this is the result. I do...
nuffodds
Thanks StephenB, I have already tried R-Linux amonst others with no success. I will try again tomorrow using disk 1.
Aug 22, 2017Guru - Experienced User
On the duo v1, the "parity disk" is mirrored, but there is no data volume partition. Usually the "parity disk" is disk 2, but that depends on the install history.
- nuffoddsAug 23, 2017Aspirant
The install was done a very long time ago. I would guess I went with the default options.
R-Linx has scanned and found my data. It is going to take a long time but I satidfied. Did a test on a small part of the data and it has recovered. So I restarted it and left it to do it's thing.
Thanks for you help.
