LrdShaper
Apr 29, 2009Aspirant
Privoxy Add-on v1.0 (ReadyNAS NV+/NV/Duo/1100/600/X6)
Privoxy Add-on for ReadyNAS sparc devices - a non-caching web proxy with advanced filtering capabilities for enhancing privacy, modifying web page data and HTTP headers, controlling access, and removing ads and other obnoxious Internet junk. This add-on is based on Privoxy v3.0.3
Requirements: RAIDiator 4.1.4+
Platform: Sparc (NV/NV+/1100/Duo)
Addon Version: v1.0
Download link: http://devrandom.blogsite.org/projects/ ... on_1.0.tar
Privoxy Version: v3.0.3
Privoxy Homepage: http://www.privoxy.org
Usage:
After installation Privoxy will start listening to default port 8118. Then in your browser, change the proxy to your ReadyNAS' IP Address and put 8118 in the port number.
If you have the Squid Add-on installed you can chain Squid to Privoxy. The main benefit of chaining Squid and Privoxy is you decrease the resource usage of Privoxy because of the local web cache provided by Squid. What this gives you is increased web performance because of Squid's local web cache plus the ad and banner filtering feature of Privoxy. To chain Squid to Privoxy you just need to add the following line in Squid's configuration file (squid.conf)
The first line assumes Privoxy is running on the same machine and listens to port 8118. If Privoxy is running on a different machine then change localhost to the IP Address of the machine running Privoxy. The second line forces squid to forward all requests to Privoxy.
Cheers!
Addon Version: v1.0
Usage:
cache_peer localhost parent 8118 0 no-query no-digest
never_direct allow all
Cheers!
- tomallen35AspirantThanks for that! I've got it working but doesn't seem to want to work with iPlayer - video page loads but video never starts. Could be something else my end though as I've not really looked into it yet.
Still, it's got me further than I've managed to get so far! Thanks again! - janjonkerAspirantHello, when I want to install this on my NV+ I get the following error "Invalid checksum detected in the update file. Update aborted".
Some additional details:
Firmware: RAIDiator 4.1.8 [1.00a043]
Memory: 1024 MB [2.5-3-3-7]
Any suggestion on how to resolve?
Or are the better (cashing) proxy servers I can use on my ReadyNAS NV+ [X-RAID]?
Thanks.
Jan Jonker
