Chase_Karr
Apr 13, 2024Tutor
Problem upgrading ReadyNAS Ultra 4 to OS 6
I have encountered a problem upgrading my Netgear ReadyNAS Ultra 4 (Model Number RNDU4000, with four 2-TB drives) to OS 6 and am looking for suggestions. Before attempting the upgrade I replaced ...
- Apr 13, 2024
Chase_Karr wrote:
Now what?
It could be an issue with the disk, so perhaps test it in a PC with vendor tools.
You could also try a factory default from the front panel (either with the current disk or a different one).
Sandshark
Apr 13, 2024Sensei
It sounds like you need a USB recovery (/RAIDiator-4-2-USB-Recovery-Tool). You need to make an OS4.2.x style recovery USB, but put the image you used for the conversion in place of the OS4.2.x image.
- Chase_KarrApr 13, 2024Tutor
Thanks for your response, Sandshark!
Following your suggestion and the instructions in the link provided, starting usbrecovery.exe on a Windows 10 PC resulted in an error message that said in part "The application has failed to start because its side-by-side configuration is incorrect." Checking Windows' Event Viewer led me to install "Microsoft Visual C++ 2005 SP1 Redistributable Package", which fixed that problem.
Used a 1-GB USB drive and created the recovery USB. It was noticed that usbrecovery.exe would not "see" R4toR6_6.9.5.bin even when it was the only BIN file in the directory. Renamed R4toR6_6.9.5.bin to RAIDiator-x86-R4toR6_6.9.bin then it appeared and was selected. Usbrecover.exe reported "Not responding" for a few seconds during the process, but then later said "Done".
Followed the instructions from the link you provided, but after holding the Backup button for 15 seconds (by a watch) the device started its normal boot process. Tried longer times in five-second increments, same results until I held the Backup button for 30 seconds. Never saw anything on the LCD that said anything about USB Recovery mode, just the far left block in the upper row blinking on and off.
But then a bit over 60 seconds after releasing the Backup button the device powered down, just as predicted in the instructions! (The instructions did not suggest a time to power down.)
Removed the USB drive and tried booting normally, but no joy, it still stalls out at 80-plus percent and showing "quotarpc.service" on the display.
Downloaded R4toR6_6.9.5.bin again from the same link as before and re-created the recovery USB, same results.
Now what?
- StephenBApr 13, 2024Guru - Experienced User
Chase_Karr wrote:
Now what?
Thanks for your assistance, StephenB!
Used the boot menu to initiate "Factory default". It seemed to boot normally and the fan(s) slowed down.
Perhaps most importantly, after "Booting" finished it displayed an IPv4 address, then "ReadyNAS Ultra 4 / 6.9.5". That makes me think it actually did upgrade.
Now it is showing "Resync data:", which at current rate will take until sometime tomorrow morning.
Am now able to access the Admin page using the IPv4 address displayed. The Admin page also showed 6.9.5. Great!
Will report back tomorrow after the resync process is done.
- SandsharkMay 27, 2025Sensei
For the tool to see it, the file must be named similarly to an OS4 firmware update, which have no extension. Try naming it something like RAIDiator-x86-6.9.5.
