marcusp
May 13, 2015Tutor
Problem with Istat after several months
Hello, I'm using my Readynas 102 just as a backup of my good old Readynas Pro 6, so the initial configuration has never changed, I'm just doing the OS updates from time to time. Last time I noti...
marcusp
Jun 07, 2015Tutor
I've made an OS reinstall but it didn't solver anything :? ...
here is a part of systemd-journal:
Do you have any solution ?
Line 4715: Jun 07 11:32:01 ReadyNAS-102 apache_access[1519]: 192.168.1.10 "GET /apps/logo/istat.png HTTP/1.1" 200
Line 4717: Jun 07 11:32:04 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4718: Jun 07 11:32:04 ReadyNAS-102 istat[1760]: /apps/istat/bin/arm/istatd: no process found
Line 4719: Jun 07 11:32:04 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4720: Jun 07 11:32:04 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4721: Jun 07 11:32:05 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4722: Jun 07 11:32:05 ReadyNAS-102 istat[1777]: /apps/istat/bin/arm/istatd: no process found
Line 4723: Jun 07 11:32:05 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4724: Jun 07 11:32:06 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4727: Jun 07 11:32:07 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4728: Jun 07 11:32:07 ReadyNAS-102 istat[1795]: /apps/istat/bin/arm/istatd: no process found
Line 4729: Jun 07 11:32:07 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4730: Jun 07 11:32:07 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4731: Jun 07 11:32:08 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4732: Jun 07 11:32:08 ReadyNAS-102 istat[1811]: /apps/istat/bin/arm/istatd: no process found
Line 4733: Jun 07 11:32:08 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4734: Jun 07 11:32:08 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4735: Jun 07 11:32:09 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4736: Jun 07 11:32:09 ReadyNAS-102 istat[1829]: /apps/istat/bin/arm/istatd: no process found
Line 4737: Jun 07 11:32:09 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4738: Jun 07 11:32:09 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4739: Jun 07 11:32:10 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4740: Jun 07 11:32:10 ReadyNAS-102 istat[1847]: /apps/istat/bin/arm/istatd: no process found
Line 4741: Jun 07 11:32:10 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4742: Jun 07 11:32:11 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4743: Jun 07 11:32:11 ReadyNAS-102 systemd[1]: fvapp-istat.service start request repeated too quickly, refusing to start.
Line 4764: Jun 07 11:32:25 ReadyNAS-102 readynasd[1260]: Delete /apps/istat
Line 4772: Jun 07 11:32:27 ReadyNAS-102 readynasd[1260]: Application 'istat' is uninstalled successfully.
Line 4850: Jun 07 11:32:40 ReadyNAS-102 fv-app-install[2178]: [istat](0%) prepare
Line 4853: Jun 07 11:32:44 ReadyNAS-102 fv-app-install[2178]: apt-get install istat
Line 4857: Jun 07 11:32:46 ReadyNAS-102 readynasd[1260]: dpkg-query: package 'istat' is not installed and no information is available
Line 4860: Jun 07 11:32:46 ReadyNAS-102 fv-app-install[2178]: [istat](5%) download 1/1 dpkg -s istat 0/1151448
Line 4861: Jun 07 11:32:50 ReadyNAS-102 readynasd[1260]: Selecting previously unselected package istat.
Line 4863: Jun 07 11:32:50 ReadyNAS-102 readynasd[1260]: Unpacking istat (from .../istat-1.0.4-all.deb) ...
Line 4866: Jun 07 11:32:52 ReadyNAS-102 readynasd[1260]: Package: istat
Line 4875: Jun 07 11:32:52 ReadyNAS-102 readynasd[1260]: /etc/init.d/istat newconffile
Line 4878: Jun 07 11:32:52 ReadyNAS-102 fv-app-install[2178]: [istat](50%) install 1/1 dpkg -s istat
Line 4879: Jun 07 11:32:52 ReadyNAS-102 readynasd[1260]: Setting up istat (1.0.4) ...
Line 4894: Jun 07 11:32:58 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4895: Jun 07 11:32:58 ReadyNAS-102 istat[2420]: /apps/istat/bin/arm/istatd: no process found
Line 4896: Jun 07 11:32:58 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4897: Jun 07 11:32:58 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4898: Jun 07 11:32:59 ReadyNAS-102 fv-app-install[2178]: [istat](100%) complete
Line 4899: Jun 07 11:33:00 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4900: Jun 07 11:33:00 ReadyNAS-102 istat[2447]: /apps/istat/bin/arm/istatd: no process found
Line 4901: Jun 07 11:33:00 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4902: Jun 07 11:33:00 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4907: Jun 07 11:33:01 ReadyNAS-102 readynasd[1260]: Service 'fvapp-istat.service' goto unexpected state 'inactive'. Expect to be 'active'('activating').
Line 4908: Jun 07 11:33:01 ReadyNAS-102 readynasd[1260]: Application 'istat' is installed successfully.
Line 4919: Jun 07 11:33:04 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4920: Jun 07 11:33:04 ReadyNAS-102 istat[2582]: /apps/istat/bin/arm/istatd: no process found
Line 4921: Jun 07 11:33:05 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4922: Jun 07 11:33:05 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4923: Jun 07 11:33:06 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4924: Jun 07 11:33:06 ReadyNAS-102 istat[2602]: /apps/istat/bin/arm/istatd: no process found
Line 4925: Jun 07 11:33:06 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4928: Jun 07 11:33:06 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4929: Jun 07 11:33:07 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4930: Jun 07 11:33:07 ReadyNAS-102 istat[2618]: /apps/istat/bin/arm/istatd: no process found
Line 4931: Jun 07 11:33:07 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4932: Jun 07 11:33:07 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4933: Jun 07 11:33:08 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4934: Jun 07 11:33:08 ReadyNAS-102 istat[2634]: /apps/istat/bin/arm/istatd: no process found
Line 4935: Jun 07 11:33:08 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4936: Jun 07 11:33:09 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4937: Jun 07 11:33:10 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4938: Jun 07 11:33:10 ReadyNAS-102 istat[2652]: /apps/istat/bin/arm/istatd: no process found
Line 4939: Jun 07 11:33:10 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4940: Jun 07 11:33:10 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4943: Jun 07 11:33:11 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4944: Jun 07 11:33:11 ReadyNAS-102 istat[2668]: /apps/istat/bin/arm/istatd: no process found
Line 4945: Jun 07 11:33:11 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4946: Jun 07 11:33:11 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4947: Jun 07 11:33:11 ReadyNAS-102 systemd[1]: fvapp-istat.service start request repeated too quickly, refusing to start.
Line 4958: Jun 07 11:33:37 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4959: Jun 07 11:33:38 ReadyNAS-102 istat[2706]: /apps/istat/bin/arm/istatd: no process found
Line 4960: Jun 07 11:33:38 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4961: Jun 07 11:33:38 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4962: Jun 07 11:33:39 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4963: Jun 07 11:33:39 ReadyNAS-102 istat[2722]: /apps/istat/bin/arm/istatd: no process found
Line 4964: Jun 07 11:33:39 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4965: Jun 07 11:33:39 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4966: Jun 07 11:33:40 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4967: Jun 07 11:33:40 ReadyNAS-102 istat[2742]: /apps/istat/bin/arm/istatd: no process found
Line 4968: Jun 07 11:33:40 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4969: Jun 07 11:33:40 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4972: Jun 07 11:33:41 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4973: Jun 07 11:33:41 ReadyNAS-102 istat[2758]: /apps/istat/bin/arm/istatd: no process found
Line 4974: Jun 07 11:33:41 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4975: Jun 07 11:33:41 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4976: Jun 07 11:33:42 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4977: Jun 07 11:33:42 ReadyNAS-102 istat[2776]: /apps/istat/bin/arm/istatd: no process found
Line 4978: Jun 07 11:33:42 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4979: Jun 07 11:33:43 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4980: Jun 07 11:33:44 ReadyNAS-102 systemd[1]: fvapp-istat.service: main process exited, code=killed, status=11
Line 4981: Jun 07 11:33:44 ReadyNAS-102 istat[2794]: /apps/istat/bin/arm/istatd: no process found
Line 4982: Jun 07 11:33:44 ReadyNAS-102 systemd[1]: Unit fvapp-istat.service entered failed state.
Line 4983: Jun 07 11:33:44 ReadyNAS-102 systemd[1]: fvapp-istat.service holdoff time over, scheduling restart.
Line 4984: Jun 07 11:33:44 ReadyNAS-102 systemd[1]: fvapp-istat.service start request repeated too quickly, refusing to start.
