TypeteType
Jul 13, 2011Aspirant
Problems postprocessing some nzbs
Hi I have some issues postprocessing some files that are dl-ed through my sabnzbd addon. This is the error msg I get: Deadliest.Catch.S07E14.The.Island.720p.HDTV.x264-MOMENTUM - PostProcessing w...
sphardy1
Jul 14, 2011Apprentice
TypeteType wrote:
this only happens to about 10% of my dl-ed files (which are all are sent to the .../TV/ folder)
So it would appear you have a permissions problem related to the TV folder
See the "Fixing Permissions" section at the bottom of this post - should correct this
