pimeson
Feb 17, 2012Aspirant
problems with EnableRootSSH (ARM) on Raidator 5.3.3
ReadyNAS DUO V2 1. Downloaded http://www.readynas.com/download/addons/arm/5.3/EnableRootSSH_1.0-arm.bin 2. Tried to install, said it was partially completed, would you like to restart? yes 3. I g...
amac27
Mar 10, 2012Aspirant
you shoule be able to get something like this on the logs
Fri Mar 9 20:29:00 PST 2012
Successfully enabled root SSH access. The root password is now the same as your admin password.
Can you try to download the rootSSH addon on another computer? I think it might be just corrupted.
If not please open a ticket with support.
