dangrew
Feb 23, 2012Aspirant
Problems with KMotion
Hi, I've installed KMotion (v2.15a-rnx86-0.2.6) on my Ultra 4 Plus (4.2.19) and have been trying to hook up a D-Link IP camera (Zoneminder supported). When I add the URL for the .cgi I get the mess...
sleepy06405
Jun 15, 2012Aspirant
Any luck with this issue? I'm experiencing same. Install kmotion, tried to enable a network cam, receive message about daemon restart, lose frontview access, apache log indicates MaxClients has been reached, this explains non responsive frontview. Reboot with ssh, frontview is fine until the kmotion url is accessed. kmotion never saves config of attempted camera add either. kmotion Logs and Load menu items just say downloading data and don't appear to work.
I'm wondering if this is an issue with the python module for apache? It seems to be using 2.6 module from the readynasxtras python add on. I also have 2.7 installed which I compiled from source. I've tried to point /usr/bin/python at the 2.6 and 2.7 binaries, no luck. Plex and BIF server both using python just fine.
Anyone got a solution or thoughts before I start digging for the cause?
