dangrew
Feb 23, 2012Aspirant
Problems with KMotion
Hi, I've installed KMotion (v2.15a-rnx86-0.2.6) on my Ultra 4 Plus (4.2.19) and have been trying to hook up a D-Link IP camera (Zoneminder supported). When I add the URL for the .cgi I get the mess...
sleepy06405
Jun 15, 2012Aspirant
Something goes wrong during the install of kmotion for some of us, not sure what causes it. To fix it, you'll need root ssh access and also have the admin account setup for ssh. The following worked for me, in this order:
Reboot the readynas, add your cameras if necessary and hopefully kmotion works now.
If it still doesn't work, have a look at the manual instructions for kmotion. They're not for readynas but it can help you figure out where its breaking:
http://kmotion2.googlecode.com/svn-hist ... TO_INSTALL
Hope this helps somebody out! Good luck!
As root:
rm /c/.kmotion/fifo*
chmod -R 777 /c/.kmotion
As admin:
/c/.kmotion/install.py
As root:
cd /c/.kmotion
mv kmotion /usr/local/bin
mv kmotion_ptz /usr/local/bin
