panosnl
Oct 06, 2011Aspirant
PureFTPd addon not installing
Hi, I just bought and downloaded the PureFTPd add-on ( http://www.readynas.com/forum/viewtopic.php?f=48&t=52769) I read that : This module requires PHP with SQLite3 support to be installed...
WhoCares_
Oct 06, 2011Mentor
panosnl wrote: It seems that there is not a check on PHP with SQLite3 but instead on the addon for this. If this is true, I would be very disappointed since this is not mentioned in the prerequisites.
I just checked the code and it does neither ;) Actually it uses a very outdated method to determine whether any PHP is installed and I think that you're right in thinking that this should be fixed. It would be helpful if you'd forward this to info@readynasxtras.com because the folks who are reading that account don't normally scan the forums here and I'm on the road and can't do much to fix this in a reasonable time frame.
-Stefan
