TonVH1
Oct 25, 2012Aspirant
Puzzled by ReadyNasRemote
I am new to Netgear but do have experience with Qnap & Synology. A general question is: I have now found 3 different places (Readynas, Community, ReadyNasExtra). I find this unnecessary complex. Is...
HERBIEO
Oct 26, 2012Aspirant
TonVH wrote:
I was specifically talking about the iPhone/iPad app like RN Remote & ReadyDLNA. These are apps I would not expect to go thru Netgear. I do know others (Qnap, Synology) where these type of apps connect directly to the NAS and do not need an intermediate.
At the same time a side question. Thru which port can I connect to the Ultra for managin access i.e. using Frontview?
Remote connections use Leaf Network service which only establishes the connection after that it is a direct peer to peer connection, one of the benefits of this is you do not have to worry about ip addresses dynamically changing,
take a look at this post more detailed info how this works > http://www.readynas.com/forum/viewtopic.php?f=75&t=30019#p165906
