tommychlee
Jun 27, 2012Aspirant
RaedyNAS Ultra2 bt
I newly buy a ReadyNAS Ultra2, but I can't find any agent or tools for bit torrent download from the CD I used Qnap before, there is an agent install in my Mac (called QGet) what will call the bt c...
HERBIEO
Jun 30, 2012Aspirant
Make sure your NAS is powered on and transmission is running then start transmission remote.
On the toolbar click options and then local settings, click the server settings tab then click add server, now select it in the list then at the bottom on the server tab put hostname of your NAS and the same port number you use to connect to Transmissions web interface from frontview, now click the authentication tab and put the same user and password you use for Transmissions web interface from frontview and tick enable authentication box, then click save and connect it should now connect.
