tommychlee
Jun 27, 2012Aspirant
RaedyNAS Ultra2 bt
I newly buy a ReadyNAS Ultra2, but I can't find any agent or tools for bit torrent download from the CD I used Qnap before, there is an agent install in my Mac (called QGet) what will call the bt c...
HERBIEO
Jul 08, 2012Aspirant
Start transmission remote then on the tool bar click options then local settings, then click server settings tab and click add server then select it in the box below, now at the bottom on the server tab you need to put host name of your readynas in the host box and port number in the other box, that is the same port you access transmission from frontview then click save server button, now select authentication tab and put user = admin and password = password unless you have changed it, its the same user name and password you access transmission with from frontview then tick enable authentication box then click save and connect, it should now connect to transmission of coarse make sure readynas is on and transmission is enabled
