Kieran1
Jan 12, 2020Aspirant
Raidar 6.5 drive ok, Frontview, reboot & volume scan needed, not rebooting. AFP sever shows no data
Hi ReadyNAS Duo RND2000 with 1 x 2TB Seagate drive. Mac 10.11.6 I have a very old readynas duo that has 1 remaining 2TB drive running in it. All seems fine physically with unit, powered, LED'...
Kieran1
Hi thanks for message.
Firstly I think it's 4.1 I can't remember how to check this info. How do I go about accessing the drive with SMB?
How do I go about zipping the log if I can't download it. I get this error message when I try to download all logs:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<payload>Empty No Support</payload>
Thanks
Kieran
Kieran1
Access via SMB:// gives this error.
The server may not exist or it is unavailable at this time. Check the server name or IP address, check your network connection, and then try again.
Thanks
Kieran
